Date/Time: Mon, 17 Mar 2025 11:27:01 +0000
Sierra Point and Figure Chart Missing Basic Option
View Count: 1541
[2021-01-27 21:24:42] |
Alberto Gauer - Posts: 121 |
@Sierra Engineering I noticed that the PnF chart does not have the option to compress the 1 box reversal into the same column. This gives a cleaner look to the chart, it should even be something automatic when choosing 1 box reversal. I have attached 2 images, one showing the PnF in Sierra, and other showing a PnF with the correct look for 1 box reversal. |
[2021-03-22 10:55:50] |
User667559 - Posts: 27 |
Can this be implemented please? The P&F charts are quite useless this way... I also added 2 screenshots explaining the problem We are asking for: support X's and O's in the same column (when there is space). This has been asked about for years now and is supported by other programs: 2021: this thread 2017: POint and figure 2014: 1 Box Reversal Point & Figure Chart With 'One-Step-Back' 2014: point and figure wyckoff calculation Date Time Of Last Edit: 2021-03-22 11:22:37
[2021-03-22 16:18:20] |
bebop - Posts: 13 |
I know you´re very busy at the moment with all the changes you´re implementing, but I´d like to add my voice to this request as well whenever there´s a chance to fit it in the updates schedule.
[2021-04-01 15:50:47] |
User707430 - Posts: 7 |
Yes, the Sierra Chart PnF coding requires me to keep StockCharts.com to effectively do PnF counts. There are a few of use purist out here that still do counts. Range charts are not as effective. https://www.tradingview.com/blog/en/a-new-way-to-build-1-box-p-f-charts-is-available-16018/ Thanks |
[2021-04-01 22:29:27] |
58LesPaul - Posts: 429 |
+1
[2021-04-02 10:10:21] |
NotIll - Posts: 118 |
+1.618
[2022-09-07 03:29:07] |
User266069 - Posts: 30 |
+1
[2022-09-08 22:18:33] |
Bump!!
