Date/Time: Sat, 22 Feb 2025 09:15:43 +0000
QuoteBoard
View Count: 434
[2021-01-27 21:20:41] |
User750920 - Posts: 280 |
Why does the ESH21 Daily Change reflect an amount of -28.20 when it is much more than that. The NQ and YM are also wrong. Thanks |
[2021-01-28 11:36:47] |
You need to contact the exchange about this.
