Date/Time: Sat, 22 Feb 2025 09:06:55 +0000
Can i delete Buy/Sell Column in DOM when Using Combined Buy/Sell Column
View Count: 963
[2021-01-27 18:35:01] |
Sudhirc - Posts: 54 |
In DOM i prefer to use Combined Bid/Ask Column. Is there a way to delete the default Sell Order and Buy Order Columns? Thank you. |
[2021-01-27 21:29:16] |
John - SC Support - Posts: 38116 |
If you are not wanting to see the Buy and Sell columns then you need to turn on the Market Data Columns rather than the Trading Chart DOM On. Refer to the information here: Trade Menu: Show Market Data Columns (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-28 17:15:57] |
This is really helpful, however can i request another option in the DOM Graph setting. Would like to see only volume greater than say 300 for ES Thank you. Date Time Of Last Edit: 2021-01-28 17:16:54
[2021-01-28 18:07:53] |
One way you can accomplish what you are asking for is to use the Market Depth Historical Graph and set the Display Quantity Numbers to Only After Last Bar. Then set the Lowest Quantity for Coloring to 300. If you do not want to see the rest of the Market Depth Historical Graph on your chart, then just set the colors to be the same as your background. You will find the information on the Market Depth Historical Graph here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-28 19:18:07] |
Thank you, that is what do currently and i will keep the number of days to load to a minimum. If i have too many days to load Market Depth Historical Graph study kinds of slow for the chart. Since i just came across this in DOM setting i taught it will be cool to have this option. No big deal. :-)
[2021-01-28 19:48:32] |
We always consider suggested changes, but we just cannot commit to when we may (if ever) get to them.
