Date/Time: Sat, 22 Feb 2025 08:37:59 +0000
chart and trades messed up
View Count: 482
[2021-01-27 15:33:26] |
User161516 - Posts: 4 |
to day and yesterday when i reopen or go from SIM to live i see some trades appears and messing up my pnl number as well , but statistic shows correct PNL
[2021-01-27 16:25:43] |
Refer to: Help With Daily Profit/Loss Value Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
