Date/Time: Sat, 22 Feb 2025 08:59:29 +0000
computer clock
View Count: 493
[2021-01-27 15:25:14]
User98657 - Posts: 336
I'm trying to set my computer to the server, but getting an error in the message logs that says I should "send for analysis".
[2021-01-27 15:45:01]
John - SC Support - Posts: 38116
This is the relevant message in your Log:
Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2021-01-27 09:17:43.340 *
Refer to the information here:
Global Settings Menu: Set System Date-Time from Server (Global Settings menu)
Also, we noticed that you have the following in your Message Log as well:
There is no SMS number specified. Alert SMS message not sent. | 2021-01-27 09:17:45.536 *
Which means that you have an Alert setup to send an SMS alert but the number to which the message it to send is not setup properly. This is not a problem, but if you did want to get those alerts sent to your phone, then you will need to look into this.:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#SMSNotifications
Date Time Of Last Edit: 2021-01-27 17:15:36
