Date/Time: Sat, 12 Sep 2026 09:58:59 +0000
Where are my Proxy Settings?
View Count: 2574
| [2021-01-27 12:35:05] |
| User372626 - Posts: 59 |
When I upgraded to version 2222, I can't find my Proxy Settings anymore, without this feature, with our network environment here, we can't use Sierrachart properly, the latency is very big. I know that there are many Sierrachart users in China who are using Proxy Settings, if this feature is removed, we can't use Sierrachart properly, so I hope this feature will be added. If Proxy Settings is set up to load the software, it is not possible to connect to the server. Thanks again!
| [2021-01-27 13:40:41] |
This was an oversight. We need to add a menu command to allow access to this settings window. We will get this out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-27 13:40:50
| [2021-01-28 12:54:46] |
This is really good news
| [2021-01-28 13:15:19] |
This is now released. Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-30 13:07:30] |
When I update to version 2225, I click on File-Data/Trade service settings, I can't find poxty settings, what should I do? Dear SC, can you help me? I can't lost poxty settings
Date Time Of Last Edit: 2021-01-30 13:09:51
| [2021-01-30 14:19:32] |
Select Global Settings >> Proxy Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-30 14:19:54
| [2021-11-23 13:30:45] |
Your Sierra Chart account which you have logged into this Support Board has no login. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-23 13:30:56
