Date/Time: Sat, 22 Feb 2025 09:40:06 +0000
[User Discussion] - Hourly Bars not on hour
View Count: 554
[2021-01-27 11:33:38] |
58LesPaul - Posts: 429 |
First off, my hourly bars are not on the hour, they are on the half hour but also last night one hourly bar was at 20:30 and the next was 21:15, then the rest of the hourly bars since have been on the xx:15 time period. Anyone know why? Thanks |
![]() Attachment Deleted. ![]() |
[2021-01-27 15:09:27] |
ForgivingComputers.com - Posts: 1012 |
Check your Session Start Time, the first hour will start then. If you want the hourly bars to be on the hour, change your session start time to be on the hour.
[2021-01-28 10:44:35] |
I live in CST(Chicago), If I set start time to 09:00:00 and end to 15:00:00 and for the evening session 15:00:00 and end 08:59:59, is this optimal or does it really matter one way or the other? If I have the end of main session and start of evening session as the same time will it download identical data at that point and display twice? Or am I overthinking this? Thanks |
[2021-01-28 11:38:44] |
Session end time should be 14:59:59, not 15:00:00. The data is only downloaded once.
