Date/Time: Sat, 22 Feb 2025 08:33:51 +0000
Replay Mode (Cr - R)
View Count: 516
[2021-01-27 07:51:40]
User161806 - Posts: 18
Hi there,
This might be a simple issue to fix.
For some reason when I press Cr-R the replay mode tab does not appear.
I have tried updating sierra to the latest version, resetting windows (Windows > Reset Windows)
I've even gone into the keyboard shortcuts to make sure that Cr -R is assigned to the replay mode tab... I'm out of ideas haha
Please let me know how I might be able to resolove this issue.
Thanks very much for your time.
Kind Regards,
Josh
[2021-01-27 09:33:42]
Using Window >> Reset Windows will definitely resolve this. We have never known a case where this does not work. So we are not sure what the solution would be other than to delete the main configuration file:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File
Date Time Of Last Edit: 2021-01-27 09:33:51
