Date/Time: Mon, 25 Nov 2024 16:42:35 +0000
Chartbooks will not open after update
View Count: 1041
[2014-02-23 15:51:15]
User83762 - Posts: 61
just updated Sierra, needing new market statistic symbols, and now my chartbooks will not open; "unable to read newer chartbook file format". backup chartbooks also fail.
Although download link says version 1094, file downloaded starts with 997 and that is version after update. Seems like link is incorrect and led me to old version.
Finally updated to version 1094 on previous version page; chartbooks open.
Date Time Of Last Edit: 2014-02-23 17:53:07
[2014-02-23 21:10:40]
Yes. The problem is you are actually going back to an older version. So you need to be on 1094 or higher.
Also take note of the following:
http://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX
