Date/Time: Sun, 20 Sep 2026 06:03:02 +0000
Have a nice time!
View Count: 893
| [2021-01-26 15:27:53] |
| User413489 - Posts: 21 |
Hello! Help in choosing a package of services, I do not quite understand. I need real time data from the U.S. stock market and forex Which service package should I choose? I'm sorry, I'm just not very good with English. Thanks |
| [2021-01-26 16:04:04] |
| John - SC Support - Posts: 47939 |
To start with, you need to decide whether you want the Standard (Package 3) or the Advanced Service Package (Package 5) for your Sierra Chart software. You will find the differences in the Packages here: Description of Service Packages and Pricing: Packages Then follow these instructions to select and set your package for renewal: Sierra Chart Purchase and License Information: Renewing Access Once you have that determined, then you will activate that particular package. If you are not trading the CME Group of Exchanges, then you do not need packages 10, 11, or 12, as those include the data feed for the CME Group. In order to get data for the U.S. Equities, you would use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. Refer to the information on the following page, which includes Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
