Date/Time: Sat, 22 Feb 2025 08:34:13 +0000
using chartbook on different computer
View Count: 898
[2021-01-26 10:32:05] |
User563205 - Posts: 9 |
Hi, I just copied my chartbook from computer 1 to computer 2 where I have a fresh install of Sierra. I put the file again into data folder. But when I try to open the chartbook on computer 2 I get an error "Chartbook file not found: E:\download\SierraChart\Data\scalps.Cht | 2021-01-26 11:17:58.902 *" That is actually the former path from computer 1. I checked the settings under GLobal setting - General settings and everything seems to be fine (proper location of data folder on computer 2 is set). It looks like the chartbook file itself remembers the old path from computer 1 ... Any ideas how to solve this? Thanks. EDIT: also didnt find solution here - https://www.sierrachart.com/index.php?page=doc/Chartbooks.html#CopyChartbook Date Time Of Last Edit: 2021-01-26 10:38:28
[2021-01-26 10:35:48] |
Open the Chartbook through File >> Open Chartbook. The Chartbook will be listed there.
[2021-01-26 11:38:56] |
Thanks for fast response. And sorry for not being clear enough. Actually, this is what I did: File - open chartbook and "click on the particular file with chartbook". NOW the message log gives me an error: "Chartbook file not found: E:\download\SierraChart\Data\scalps.Cht | 2021-01-26 11:17:58.902 *" I dont know why is the program looking for the chartbook at this false location... (as I wrote its location of my data and chartbook folder on my other PC) |
[2021-01-26 12:43:09] |
This is not making sense. Does that file exist or not? You cannot possibly open a file through File >> Open Chartbook when it does not exist in the list. You would not even be able to select it.
[2021-01-27 18:03:49] |
Thank you, your reaction was exactly what I needed. My bad - actually, I was trying to open my chartbook from the list of last opened chartbooks. Thats why the incorrect path. Solved.
[2021-01-28 01:47:27] |
Ok that makes sense. You need to clear that list with File >> Clear Recent File List.
