Date/Time: Fri, 21 Feb 2025 18:28:54 +0000
How to show volume bars(Study: Volume By Price) only on the current day TPO
View Count: 799
[2021-01-26 03:33:16] |
User640414 - Posts: 28 |
Hello, As you can see from the attached screenshot of my TPO chart, the volume profiles (Study: Volume By Price) are on each and every day TPO's. I like it to be set up only on the current day only. For example on this screenshot it would be on Jan 25th day and on Jan 25th over night trading only. Please advise how to set this up. http://www.sierrachart.com/image.php?Image=1611631829526.png |
Attachment Deleted. Private File |
[2021-01-26 12:57:54] |
Refer to: Volume By Price Study: Single Volume Profiles At End of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-26 15:36:54] |
Thank you for the feedback. However, I am unable to change any of the options available under Volume Graph Period type (In:33)dropdown window. It is not letting me do any changes and when I try, it automatically goes back to "Based On TPO Chart". Kind of logged. Please see that attached screenshot.
[2021-01-26 16:22:59] |
John - SC Support - Posts: 38111 |
You need to make the change to the Input Based on TPO Chart to No prior to being able to change the other parameters. Refer to the information here: Volume By Price Study: Based on TPO Chart The statement to do this is at the bottom of the section for how to get a single profile. We will move it up to the top. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
