Date/Time: Fri, 21 Feb 2025 18:27:09 +0000
Price
View Count: 510
[2021-01-25 22:24:36]
bwalks123 - Posts: 122
I just set up my live trading account through Stage 5/Advantage and will be utilizing Denali feed/SC order routing. I am currently on package 5 ($36/month) which is up for monthly renewal 2/7/21, I haven't enabled Denali feed yet and was wondering what package to chose from? I recently read in support that your rolling out standardized packages soon and want to make sure I am selecting correctly. Do I just add Denali feed and leave on package 5 advanced or select new package "11-Advanced + Denali data feed $56/month"? Do I need to choose "Update/Set" or "Update and Renew Now"?
Really appreciate the help!
[2021-01-25 22:43:11]
Yes for now you would want to use package 11. Just pay for one month at a time for now.
[2021-01-25 23:03:30]
Got it. Will the $56 for Package 11 be pro rated for the remaining 2 weeks I currently have on Package 5 Advanced? And do I click "Update/Set" or "Update and Renew Now" to activate?
[2021-01-26 09:13:27]
You need to change the Service Package and what happens is explained below.
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Update/Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
Date Time Of Last Edit: 2021-01-26 09:14:34
