Date/Time: Fri, 18 Sep 2026 12:45:36 +0000
C:\SierraChart\Data\SierraChartStudies.dll error.
View Count: 901
| [2021-01-25 22:11:23] |
| Sudhirc - Posts: 57 |
Hello, I had issues all day today with subject error and the system crashes. I had to install the software few time and now it seems to be working, but i'm still getting this error message and I'm afraid that this will crash again.. Can you suggest what i should be doing to get this rectified. thank you. |
| [2021-01-26 10:07:16] |
Regarding that particular error, it is harmless but update Sierra Chart to the latest prerelease: Software Download: Fast Update Also most likely it was your security running on your computer causing a problem with Sierra Chart installing the Sierra Chart Studies DLL file. This sounds like a problem that you are having as well based on your description. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-26 10:09:34
