Date/Time: Sat, 22 Feb 2025 09:10:00 +0000
Volume by Price study issue
View Count: 611
[2021-01-25 21:53:13]
User983039 - Posts: 11
After facing issues with chart data, I updated to new version but now Volume By Price study is out of shape. As you can see in the attached screenshot, I only got 1 day study applied to the chart but there is another one which appeared after updating. I cannot delete it and I have re-opened software few times.
I also have AAPL.BZ historical chart 5M timeframe along with some other equities charts. But data older than six months is not loading on 5M timeframe but when I change it to D timeframe then it loads as far back as 4-5 years. Is there any way to load data on 5M timeframe?
imageCapture.PNG / V - Attached On 2021-01-25 21:52:08 UTC - Size: 111.94 KB - 195 views
[2021-01-26 14:26:17]
John - SC Support - Posts: 38116
Please attach a Chartbook containing the chart that is showing the incorrect VbP to this thread, following these instructions:
As to getting additional historical data, refer to the information here:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2021-01-26 22:48:05]
Please find attached the chartbook which contains the chart.
I will follow the process of downloading additional historical data and see if it works.
Private File
[2021-01-28 08:18:15]
You can remove any instance of the Volume by Price study that you do not need through the Chart Studies window:
Chart Studies: Chart Studies Window
And you can also modify the Inputs for the Volume by Price study as you require:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Settings
[2021-01-28 15:34:09]
There is something not right with your data. We just noticed that where you are having the problem you have your dates go from 1-25 to 1-13 and then back up from there.
It looks like you are using the Sierra Chart Delayed Data, in which case redownload the data from before the 25 by following these instructions:
