Date/Time: Thu, 06 Mar 2025 15:56:28 +0000
Use As Trade Only Symbol
View Count: 3064
[2021-01-25 21:24:32] |
User566913 - Posts: 39 |
What is this feature exactly, and, do I need to have it checked for this scenario: Symbol is set to ES Trade and Current Quote Symbol is set to Micro ES .... I'm running an algo based on the Micro ES and would like it to trade ES and other symbols I apply it to. Thanks |
[2021-01-25 22:17:52] |
John - SC Support - Posts: 38434 |
It sounds like you have your Symbol and Trade and Current Quote Symbol set backwards. If you want to have a Micro ES chart and place a trade for the ES based on the Micro ES, then you need to have your Symbol set to MES (Micro ES) and the Trade and Current Quote Symbol set to ES. Refer to the information here for how these items work: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Also refer to the documentation for Use as Trade Only Symbol: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-28 07:37:39
[2021-01-25 23:11:09] |
Thanks so much. One more thing if you don't mind... .. Can I receive DOM data such as Recent Ask/Bid volume into a Spreadsheet Study/ Spreadsheet for Trading? Thanks again, very helpful |
[2021-01-26 14:31:24] |
In general the DOM data is not available within the software - you would need to use ACSIL in order to get the data. But, there are a few Pulling/Stacking data available in the Numbers Bars Calculated Values 2 study. You will find the information on these subgraphs here: Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-26 16:21:03] |
I am using ASCIL currently, but I cannot understand what a Price Tick Index, or how to set it. This is my current issue I'm dealing with, thanks
[2021-01-27 10:33:51] |
This is the actual price value divided by the tick size for the symbol.
[2021-11-29 16:12:01] |
Bhupinderjhajj - Posts: 30 |
Hello John Just reading this form. I'm trying see ES data but want to place a trade for MES. I have the following settings on my ES DOM: Symbol is set to ES Trade and Current Quote Symbol is set to Micro ES Use as Trade only Symbol - Marked as Checked However when I place a trade, it shows the same P/L as per the ES. Is it trading the MES but just showing a different P/L? or am I doing something wrong. Cheers |
[2021-11-29 18:20:27] |
Since you are using a "Trade and Current Quote Symbol", you then need to adjust the Currency Value per Tick to reflect that of the symbol in the "Trade and Current Quote Symbol" field. Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-07 21:35:24] |
User769783 - Posts: 191 |
@ User566913, please reach out to me. I have a solution for your DOM issue.
