Date/Time: Fri, 11 Sep 2026 13:23:44 +0000
Exponential Moving Averages Calculation
View Count: 3275
[2014-02-23 03:23:46]
User47706 - Posts: 24
Hello Support Engineers,
I have a C++ program which is organically replicating your EMA values to within the ten millionth exponent(decimal) across multiple time frames (2 seconds through 60 minutes) with remarkable accuracy and frequency. However, on some occasions my programmatic calculations show variances in the ten thousands. Perplexed, I attacked these variances assuming that my program was intermittently failing to calculate correctly. What my analysis has brought me to is the realization that seemingly all of my self-defined unacceptable variances occur immediately following a bar of data that closes at the same price as the bar of data preceding it (my base for the EMA calculation is the Close Price). I am using your price data files as my sole data source.
I do NOT believe anything is wrong with your EMA calculations. Many years of experience with your platform has my confidence in your service/talents at an all time high.
So, can you tell me what you do special or different in your calculations of EMA when a base input value is encountered to be the same as what has presented before it? Are you decaying that one base (Close Price) value, possibly?
Date Time Of Last Edit: 2014-02-23 03:27:31
[2014-02-23 04:35:01]
This is the actual code:
SCFloatArrayRef ExponentialMovingAverage_S(SCFloatArrayRef In, SCFloatArrayRef Out, int Index, int Length)
  if (Index >= In.GetArraySize())
    return Out;
  if(Index < 1 || Length < 1)
    return Out;
  if (Index < Length -1)
    Length = Index+1;
  float Multiplier1 = 2.0f / (Length + 1);
  float Multiplier2 = 1.0f - Multiplier1;
  float PreviousMovingAverageValue = Out[Index - 1 ];
  //Check for a previous moving average value of 0 so we can properly initialize the previous value, and also check for out of range values.
  if (PreviousMovingAverageValue == 0.0f || !((PreviousMovingAverageValue > -FLT_MAX) && (PreviousMovingAverageValue < FLT_MAX)))
    Out[Index - 1] = In[Index-1];
  Out[Index] = (Multiplier1 * In[Index]) + (Multiplier2 * Out[Index - 1]);
  return Out;
[2014-02-23 18:31:54]
Your code sample shows me what I was looking for:
. . . PreviousMovingAverageValue > -FLT_MAX . . . < FLT_MAX . . .
This is a range filter which I find conceptually challenging when it is applied to exponential moving average data. But, so be it.
Can you show me the code which populates FLT_MAX ?
Thanks,
Craig
[2014-02-23 19:49:59]
vegasfoster - Posts: 444
Maximum floating point number http://www.cplusplus.com/reference/cfloat/
[2014-02-23 20:15:29]
With floating-point calculations sometimes there could be results which are not valid numbers. The main case would be dividing by 0. This code is designed to catch numbers which are not actually valid floating-point numbers and ignore them:
