Date/Time: Fri, 21 Feb 2025 18:54:45 +0000
Daily OHLC indicator values are inaccurate for prior days
View Count: 718
[2021-01-25 20:49:10] |
User102890 - Posts: 8 |
Daily OHLC indicator is not showing accurate values for prior days . For example ,when the reference days back is set to 2 it is displaying yesterday's High and Low and same when the reference days back is set to 3 it still displays yesterday's values. It was working fine when I tested it on the weekend so not sure if this is related to start of a new week .I do not have separate day and evening sessions setup and I tried every other possible option but still same results. Also I installed the newer version . I am currently using 2218-64bit version.
[2021-01-26 07:39:20] |
We are testing this now.
[2021-01-26 08:39:06] |
This was rather involved to resolve but we do have it resolved. We had to add a new Use Sunday Data input which is now set to false by default. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-26 13:24:23] |
So what do i need to do to fix this issue ?
[2021-01-26 14:37:38] |
Update to the latest prerelease.
