Date/Time: Fri, 21 Feb 2025 18:31:40 +0000
SCString multi line?
View Count: 547
[2021-01-25 18:55:33]
grantx - Posts: 244
ACSIL Programming Concepts: SCString Examples
How do I build a multi line string with SCString(ie with carriage return)? Doesnt say in the help.
I want
to print this
on the chart
[2021-01-25 20:41:44]
John - SC Support - Posts: 38111
You would want to use the Text Drawing Tool to do this. Refer to the following in general:
Using Drawing Tools From an Advanced Custom Study
And specifically the section for the Drawing Type of DRAWING_TEXT in this section:
Using Drawing Tools From an Advanced Custom Study: s_UseTool::DrawingType
And also refer to the Text member of s_UseTool here:
Using Drawing Tools From an Advanced Custom Study: s_UseTool::Text
[2021-01-25 21:11:18]
grantx - Posts: 244
Thanks John. Another question instead of starting a new thread:
Are there any statistical functions that can be run on arrays such as:
mean,average,median,upper quartile,lower quartile, standard deviation etc..?
Also functions like:
highest, lowest, sum, etc..
[2021-01-25 22:29:38]
Have a look at the available functions here:
ACSIL Interface Members - Functions
