Date/Time: Fri, 21 Feb 2025 18:53:16 +0000
Global Tools - Horizontal Lines
View Count: 584
[2021-01-25 17:36:17]
TraderX13 - Posts: 8
Quick question is there a way to place a horizontal line on chart 1 and have it show up on all charts that display the same symbol?
Many thanks in advance.
[2021-01-25 18:54:30]
John - SC Support - Posts: 38111
Refer to the following for copying drawings:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
Or, you could also use the Horizontal Lines study along with Chart Linking for the Studies:
Horizontal Lines
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2021-01-26 18:07:06]
Thanks John - that worked as expected for tools I add by hand, however, I am using a third party study to add lines from a spreadsheet. These lines do not appear on the second chart. Is there a way to accomplish this without inserting the study on each chart?
Thanks.
[2021-01-26 18:15:29]
Use the Study Subgraph Reference study on the other charts and reference the particular subgraph (column) that contains the line. Refer to the information here:
You could also use the Study/Price Overlay, but the Study Subgraph Reference will be faster/easier for your situation since it is just a straight line. Refer to the following for the Study/Price Overlay:
Study/Price Overlay Study
