Date/Time: Sat, 22 Feb 2025 09:20:38 +0000
virus
View Count: 697
[2021-01-25 17:09:08] |
User42662 - Posts: 6 |
Hello, I wanted te re-install sierra chart. I use G data as virus controller. I got the folowing message: Virus: Gen:Variant.Mikey.118436 (Engine A) Bestand: SierraChartStudies_64.dll Map: C:\SierraChart\DownloadedInstallationFiles Proces: SierraChartFileDownloader.exe The program has been installed ( curent version) but is missing the .dll. Avery serious problem. What can you doe? Peter de Vos |
[2021-01-25 18:49:31] |
John - SC Support - Posts: 38116 |
We are getting this report a lot. There is not a virus in our file, it is a false positive. You need to go into your Anti-Virus software and create an exception for the file SierraChartStudies_64.dll and then reinstall the software again to install that file again. To install Sierra Chart again follow the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-25 22:15:30
[2021-01-29 03:56:49] |
User629746 - Posts: 7 |
i also had this problem with Bitdefender total security Variant.Mikey.118436 it removed all my studies except volume profile from the screen but not permeantly deleted from my studies i follow S.C staff recommendations and all is well again |
