Date/Time: Mon, 25 Nov 2024 17:48:48 +0000
hide chart trader
View Count: 1147
[2014-02-23 00:55:51] |
cmb999 - Posts: 211 |
hi, when I use shortcut (Ctrl-Shft-T) to hide chart-trader. It only works when window is floating. when it is docked (attached) to the right, I cannot hide it. I have to detach it first, then close. chris Date Time Of Last Edit: 2014-02-23 00:56:34
[2014-02-23 19:41:21] |
vegasfoster - Posts: 444 |
You can shrink it, but as far as I know you can not hide it. It would be cool if you could press an arrow to shink, then press again to hide, then press again to unhide, then press again to unshrink.
[2014-02-24 09:46:55] |
You can close the Trade Window by selecting Menu/M >> Close Trade Window on the Trade Window itself.
[2014-02-24 22:39:56] |
yes, but Ctrl-Shift-T to bring it back up again defaults it to floating . .
Date Time Of Last Edit: 2014-02-24 22:40:28
[2014-02-24 22:44:29] |
You need to set up a shortcut key for Trade >>Attach Trade Window to Chart. This will also open the Trade Window if it is not open.
[2014-02-25 03:27:44] |
close, once I click Ctrl-Shift- t again, it does not hide chart trader, only floats it. Date Time Of Last Edit: 2014-02-25 03:29:11
[2014-02-25 05:59:50] |
Yes, this makes sense.
