Date/Time: Fri, 21 Feb 2025 18:37:26 +0000
Martin Luther King Day historical data missing
View Count: 639
[2021-01-25 15:25:53] |
User350416 - Posts: 43 |
Hi, On my daily chart only the daily candle of monday 18 of January (MLK day) is missing. I tried reloading the data (delete all and download data) but it doesn't fix the issue. I have a direct SC advanced subscription meaning I should be receiving historical data from SC. For info my intraday data is provided by rithmic, but ihave no issues on my intraday chart (for ie. the 18/01 missing data is showing on the 60 min charts) Thank you for your help. |
[2021-01-25 17:34:50] |
John - SC Support - Posts: 38111 |
Since January 18, 2021 was a US Holiday, there is no daily data transmitted from the exchange for that day. What you are seeing is correct.
[2021-01-26 07:27:51] |
Well that should be incorrect as Globex was open and I have intraday data for the 18/01. Therefore there should be a daily candle for that day see attached http://www.sierrachart.com/image.php?Image=161164599195.png |
[2021-01-26 08:39:45] |
Please do not contact us about this. You need to ask the exchange.
[2021-01-26 20:39:18] |
User90125 - Posts: 715 |
CME Group Global Office Contacts |
