Date/Time: Fri, 21 Feb 2025 18:55:01 +0000
Manually download of Lost SCID files? (CQG no longer supported)
View Count: 489
[2021-01-25 12:31:42] |
Jezz - Posts: 33 |
Hi. Due to recent issues with CQG and new Sierra versions, I have lost 2 emini ES contract from my historical data, and I need them for backtesting: - F.US.EPU20.scid (sept 2020) - F.US.EPZ20.scid (dec 2020 I'm considering move to new Denali package 10, but it will take some time until figuring out if AMP futures will provide the new package or getting it directly from Sierra... In the meantime, Is there any way of manually download these 2 files from anywhere? Can anyone share them? Thanks in advance |
[2021-01-25 23:02:13] |
Use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
