Date/Time: Fri, 21 Feb 2025 18:37:31 +0000
Failure to download SierraChartStudies_64
View Count: 516
[2021-01-25 07:41:37] |
User846336 - Posts: 1 |
I tried to update SierraChart to latest version, but my anti-virus software blocked the process. Here is the log message: "The file C: \ SierraChart \ DownloadedInstallationFiles \ SierraChartStudies_64.dll is infected with Gen: Variant.Mikey.118436 and has been placed in quarantine. We recommend that you perform a system scan to verify that your system is healthy." Can you please let me know if you received similar messages? Cheers.
[2021-01-25 11:15:19] |
Yes we have been hearing about this lately but the file is definitely safe. It is a false positive. You need to make sure that your security software is excluding that file.
[2021-01-25 15:02:18] |
auggie - Posts: 45 |
Bitdefender is blocking it also
[2021-01-25 20:51:41] |
Ok, we are not sure why this is happening. There is nothing wrong with the Sierra Chart studies file.
