Date/Time: Fri, 21 Feb 2025 18:32:58 +0000
All Brooks
View Count: 675
[2021-01-25 07:33:31] |
Carol - Posts: 1 |
Hi, is there an ALL brooks indicator? thx |
[2021-01-25 16:52:22] |
John - SC Support - Posts: 38111 |
We found a reference to Al Brooks indicator as "It finds and labels H, L, Outside, and Inside bars". If that is what you are looking for, then you can recreate it in Sierra Chart by using the following studies: High/Low for Time Period Inside Bar Outside Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
