Date/Time: Fri, 21 Feb 2025 18:32:53 +0000
Cost of using DTCprotocol
View Count: 474
[2021-01-25 07:07:58] |
User61576 - Posts: 445 |
few questions: 1. can I pay for only the data feed of denali in order to use the DTC protocol? 2. can I get historical data via the DTC protocol? 3. do I need to pay for SC as well? 4. if I will record the DTC session for NQ (for example) and later compare it with scid file in SC, will they be identical? 5. can I request from DTC to get volume bars only? 6. from your experience, is there any diff. between your data feed and TT's? prices? |
[2021-01-25 08:07:02] |
You are already using the Denali Exchange Data Feed. You need to also pay for Sierra Chart in addition to the Denali Exchange Data Feed to use the the Denali data feed. Yes historical data is supported through the DTC protocol server. 4. Yes. Assuming you are not making any mistakes. 5. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-25 08:47:32] |
Can i add a second denali feed? This will be located on a different server Do i need to run sc client for getting the data via dtc? Any comments about tt data feed? |
[2021-01-26 09:20:45] |
how do I use SC with DTCprotocol/server over linux?
[2021-01-26 09:39:40] |
Can i add a second denali feed? This will be located on a different server Refer to:Denali Exchange Data Feed: Connections Do i need to run sc client for getting the data via dtc? Yes the data is only accessible through Sierra Chart.Any comments about tt data feed? This is not within the scope of our support. However, the Denali Exchange Data Feed is a perfect data feed.how do I use SC with DTCprotocol/server over linux?
You just need to run Sierra Chart on Linux. There are many discussion threads on this Support Board about that.
