Date/Time: Fri, 21 Feb 2025 18:34:49 +0000
Trading DOM - Interactive Brokers - US Equities SMART routing supported?
View Count: 503
[2021-01-25 07:05:03] |
User100912 - Posts: 104 |
Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks states "You cannot use SMART for the exchange code.". Is it supported to SMART route orders from the Sierra Chart Trading DOM to US Stocks with IB? |
[2021-01-25 08:07:32] |
Yes in the case of US stocks for Interactive Brokers you just simply use the standard simple stock symbol: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-25 08:24:23
