Date/Time: Fri, 21 Feb 2025 18:48:59 +0000
Add Symbol Value Format
View Count: 436
[2021-01-25 02:09:36] |
User128888 - Posts: 30 |
Hi, I have ES (main price graph) and GC (add symbol) on a chart. ES value format on the chart shows (as an example) 3845.75 but GC shows up as 18543.00 . GC should show as 1854.3 . I can't seem to make GC show as 1854.3 . Attached is screenshot of where I'm talking about. Is there a way for me to update it so GC shows up with the proper value? Thanks. |
[2021-01-25 07:03:30] |
Yes. This is controlled with the Price Multiplier Input with the study.
