Date/Time: Fri, 21 Feb 2025 18:31:50 +0000
ES; problems with setting up time
View Count: 478
[2021-01-23 17:15:19] |
User670350 - Posts: 19 |
Dear All; I just noticed that my 10 ticks chart has morning session from 00-23.59 and the range from June till yesterday. I tried many times and the system doesn't allow me change hours. When I click OK and Apply it looks like is reloading and changing but when it stop and I check it-it doesn't change and I tried it many times. Of course I was able to always change it before. All my other charts are set up correctly. Any advice? Thank you; Andrzej |
Attachment Deleted. |
[2021-01-24 01:30:26] |
Refer to: Chart Session Times: Session Times Automatically Changing Unexpectedly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-24 18:12:26] |
Sorry but you didn't replay to my question at all and just copy and paste info that I know anyway. What I stated that I have bunch of charts in my chartbook and all have morning and evening trading hours as my 5 tick chart-please see attachments. The only chart that I can't set it up for some reason is 10 tick chart. Could you please help me with that? Thank you; |
