Date/Time: Sat, 12 Sep 2026 22:22:54 +0000
Problems with Replay Feature
View Count: 1592
| [2021-01-23 12:25:15] |
| User670350 - Posts: 19 |
Dear All; My Replay feature stopped working and I didn't touch anything in the settings. It happened once in the past when restarted by itself after some times. I am with TradeProAcademy and my friend also don't know what is wrong. I am attaching a picture how it looks and also my Replay settings in ZIP File I would appreciate your help very much. Thank you; Andrzej |
| Private File |
| [2021-01-24 05:13:38] |
First thing we want you to do is to update to the current version: Software Download: Fast Update And we also want you to uncheck the Use Start Date-Time option on the replay window and instead scroll the chart back to where you want to start the replay from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-24 05:13:51
| [2021-01-24 18:08:26] |
Dear All; You told me to download the newest version of sierra, which I did. However you also stated "And we also want you to uncheck the Use Start Date-Time option on the replay window and instead scroll the chart back to where you want to start the replay from." How do you expect me to do it and link all the charts? If I don't state the time I want to start replay-it is not going to move at all Could you clarify this for me please? |
| [2021-01-25 16:36:16] |
| John - SC Support - Posts: 47854 |
If you scroll the chart back it will start the replay for all the charts that are defined to be replayed, from that point. Follow the step-by-step instructions here: Replaying Charts: Basic Chart Replay Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-28 07:39:10
