Date/Time: Fri, 21 Feb 2025 18:27:22 +0000
OHLC bars - Open & Close tick colors
View Count: 1098
[2021-01-23 10:54:16]
aelagha - Posts: 31
I can set the color of the open/close ticks (horizontal lines) for OHLC bars independent from the bar colors. Is there a way to force painting these ticks to correspond to the "Bar High-Low Down" and "Bar High-Low Up" colors, so that if the bar closes down, both ticks have the same color as
"Bar High-Low Down" color, and if it closes higher, the ticks have the same color as "Bar High-Low Up"?
thx
[2021-01-23 11:27:10]
Refer to this option:
Graphics Settings: Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other)
