Date/Time: Fri, 21 Feb 2025 18:54:12 +0000
Gann Hi Lo Activator (unable to change from being red)
View Count: 572
[2021-01-23 03:29:26] |
User873998 - Posts: 11 |
Hi There, when using the gann hi lo activator it seems it is locked as red when bearish. With no option to change the color scheme (see attachments) Perhaps I'm missing something? Please advise on how I can change it from being stuck as red if possible. If not- will you please make an adjustment to this study so just as one can change the color when bullish, a person can also change the color to their liking when bearish. thank you. |
[2021-01-23 10:26:28] |
You can change the colors through the Subgraphs tab of the Study Settings window: Chart Studies: Subgraphs Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-23 10:28:08
[2021-01-23 17:33:13] |
That's precisely what I'm getting at. In the subgraphs there is no ability to change it from being red. The only ability currently available is to change the color of the "bullish" gann There is currently no ability to change the color of the "bearish" gann That's why I posted the screenshot of the subgraph to show that. |
[2021-01-25 16:02:02] |
John - SC Support - Posts: 38111 |
Sorry, for some reason the ability to change the Secondary Color was not made available in this case. So there currently is not a way to change the color. We have updated the study to show both the Primary and Secondary colors. This will be available in the next Pre-Release (v 2224). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
