Date/Time: Fri, 21 Feb 2025 18:28:31 +0000
Old chart data compression
View Count: 537
[2021-01-22 22:57:10] |
Ryan McDonald - Posts: 9 |
I see the new interface for the Data Trade Service Settings and the documentation is not updated, so do/can we still compress old chart data to speed up the load time?
[2021-01-22 23:08:59] |
John - SC Support - Posts: 38111 |
Parts of the Data/Trade Service Settings were split off and made available separately. If you are looking for the Intraday Data File Management window, then you can get to this by selecting Global Settings >> Intraday Data File Management. It is located on the bottom right in the pulldown menu. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
