Date/Time: Fri, 21 Feb 2025 18:28:16 +0000
Moving to AMP Futures from Edge Clear
View Count: 2003
[2021-01-22 15:43:24]
User504980 - Posts: 24
I just realized Edge Clear is not the best for me because I'm small-time, and their margins are high, so I'm moving to AMP Futures. Edge Clear (Phillip Capital) will be transferring funds to my account at AMP Clearing today or tomorrow.
1. I will have a period where I have no funded account, since there would presumably be at least a day hold at AMP. How does that impact me with the CME rules that I have a funded account?
2. Will the current services / configuration options with Edge Clear work seamlessly with the AMP account? I mean, do I have something that's not necessary, overkill, or just won't work right with AMP? I think I'd like to stick with SC services / data / routing as much as possible.
3. Anything else I need to know about to move from Broker to Broker?
TIA
[2021-01-22 22:37:47]
John - SC Support - Posts: 38111
1. A small period of time without having a trading account will not impact you at all with regards to the CME Rules. Each time you login, it updates the expiration date for the check, which is one month forward. In your case, at the moment of us writing this response, your expiration is showing February 17, 2021.
2. With regards to Sierra Chart, everything will be exactly the same, since you are using our Order Routing and Data.
3. Just make sure you let us know when the AMP account is setup so we can update your Trading Account information. Start an Account Support Ticket for when this happens:
https://www.sierrachart.com/index.php?page=doc/SelfHelp.php&Source=Ticket
