Date/Time: Fri, 21 Feb 2025 18:33:08 +0000
sunbscriptiom
View Count: 556
[2021-01-22 15:41:54] |
Kevin McGee - Posts: 8 |
I am trying to set up an account with you. I want to set up a monthly direct debit for the platform and data feed can u help me out. If i go through you which brokers can i put my orders through I trade the Emini NQ100 oil and that's about it. |
[2021-01-22 22:34:10] |
John - SC Support - Posts: 38111 |
We do not offer a Direct Debit option, nor are we looking to do so. We are working on allowing recurring charges to a credit card and we should have that available in the next few weeks. For now, you can pay by Credit Card, PayPal or Wire Transfer. In all of these cases, you have to initiate the transfer. You can make a payment on this page: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit In terms of a broker, you would need one that supports one of the Trading Services that we work with. You will find the list of trading services here: Supported Data and Trading Services: Supported Services We recommend the Sierra Chart Order Routing Service, in which case a partial list of brokers is in Step #2 of the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-25 17:53:10] |
i will top it up once a month how do i link my broekr to u
[2021-01-25 18:57:58] |
What trading service does your broker use?
[2021-01-26 09:08:45] |
You need to tell us who your Futures broker is.
