Date/Time: Fri, 21 Feb 2025 18:31:22 +0000
AMP Demo Accounts are no longer available
View Count: 609
[2021-01-22 15:37:52] |
User646846 - Posts: 1 |
I installed Sierrachart recently as a first time, in order to trade Future contracts, and I tried to get an AMP Futures demo account to use with Sierrachart. They mentioned DEMO accounts are no longer available. May you recommend any other Futures Broker?. By the way, dont you have a Sierra Chart Data feed itself?.
[2021-01-22 22:29:46] |
John - SC Support - Posts: 38111 |
The reason we no longer support the Demo accounts is because you can accomplish the same thing using Sierra Chart, in particular in combination with the Simulated Futures Trading Service. Refer to the information here: Simulated Futures Trading Service Therefore, there is no reason to change brokers. We do have our own data feeds. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-23 00:51:43] |
Refer to this page: Basic Instructions for Sierra Chart Demo for Brokerage Customers And also this page for the delay data feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
