Date/Time: Fri, 21 Feb 2025 18:44:59 +0000
chart payment with AMP
View Count: 560
[2021-01-22 15:20:22]
User621961 - Posts: 1
thank you very much for your attention, by the way, I have data with CQG, I would like to know what kind of data you recommend that also cost 1 USD monthly to change the data provider and use sierra chart without problems because I am failing the graphs, thanks.
[2021-01-22 22:25:09]
John - SC Support - Posts: 38111
Tell us the exchanges for which you want data so we can give you the correct information.
[2021-01-23 01:16:01]
We recommend using the Denali Exchange Data Feed:
