Date/Time: Fri, 21 Feb 2025 18:44:26 +0000
I cannot connect
View Count: 463
[2021-01-22 15:16:30] |
User937712 - Posts: 1 |
Hello Team from Sierra chart. Actually i want to connect my trading account with sierra tradings station. But i dont know what i doing wrong. It doesent works. Could you please help me with it?
[2021-01-22 22:23:08] |
John - SC Support - Posts: 38111 |
If you mean you want to use the Sierra Chart Order Routing Service, then as long as you have a broker that supports this service (see the Setup Instructions item #2) then just follow the Setup Instructions to connect your accounts and get this setup. Here is the link to the Setup Instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-23 01:10:05] |
Regarding post #1, who is your broker?
