Date/Time: Thu, 24 Sep 2026 13:35:31 +0000
price range highlight
View Count: 1975
[2014-02-22 12:44:40]
User16114 - Posts: 153
Time Range Highlight allows coloring of chart background vertically depending on time.
Is there a way to color the background of a chart horizontally by price?
ie: green background from 500 to 999 and a different color from 1000 to 1499 etc.
[2014-02-22 23:19:19]
Yes. Look at using the Horizontal Lines study. And set Subgraph pairs to be filled:
https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea
[2021-04-05 18:24:54]
User676363 - Posts: 90
The link above references a document with another link to a "Horizontal Lines" study
Unfortunately this link points to the wrong location.
It should point to: Horizontal Lines
In addition, SierraChart has a study called "Horizontal Line at Time".
However, clicking the help button on this study doesn't provide a link that is specific to that study.
I believe it should be sending me here: Horizontal Line at Time
Can somebody perhaps fix those two situations, please?
[2021-04-05 19:42:43]
John - SC Support - Posts: 47994
We have taken care of the link to the Horizontal Lines in the Filling between two Subgraphs section.
The other help that you are referencing does not take you to the specific study help. It opens to the Chart Studies page to help you get a study on the chart. So there is nothing to change there.
