Date/Time: Wed, 26 Feb 2025 13:58:05 +0000
[User Discussion] - Crypto historical Data
View Count: 659
[2021-01-21 23:43:25] |
User558377 - Posts: 31 |
I'm using the data included with sierra chart package 5. Using binance data, trying to load historical charts specifically weekly charts for link/usd, link/gbp. It only seems to load a few weeks worth of data. I would like to load much more than that, years preferably. Is this possible? Thank you much.
[2021-01-29 22:29:37] |
User716258 - Posts: 7 |
Same issue as well.
[2021-04-30 08:16:20] |
. Is this possible? No the historical data begins approximately January 2021 for Binance.
[2021-05-24 16:13:01] |
Cmopcap - Posts: 12 |
Hi Support, I am running a daily historical chart with binance data. The problem I currently have is that the daily bar is not rolling over to a next one (next day) according to my time settings (Sierra and Computer both have the same settings). For instance, my daily historical bar is still trading on the 23rd of may while it is already 24/05 in the entire world. I have read the time settings instructions on the website and seems to be all correct in my end. What should I do in this case please ? Many thanks C |
