Date/Time: Fri, 21 Feb 2025 18:08:54 +0000
Chart Drawing Outside of chart
View Count: 435
[2021-01-21 20:41:14]
User837393 - Posts: 142
I have a chart drawing (Stationnary Text) that I accidentaly moved to close to the border of the chart window and now I can't see it or access its properties.
Is there away to get to the list of drawings so I can edit its X and Y position so I can see it again ?
I'd like to avoid deleting all Text Drawing and start over, because I have other info that I'd like to keep.
Best regards,
[2021-01-22 00:29:15]
Refer to:
Chart Drawing Tools: Manage Chart Drawings
[2021-01-22 01:16:49]
Thanks it is working.
Now on that same topic what if I don't want this stationary text drawing to appear on other charts, BUT I do have drawings that I still want to replicate on the others charts.
What are the options ?
Best regards.
Date Time Of Last Edit: 2021-01-22 01:17:16
[2021-01-22 01:28:04]
Solved ... Thanks you.
Global Setting - Customise Chart Drawing Menu
Add : Allow Copy to other chart
Then go to the drawing and uncheck allow copy to othe chart.
