Date/Time: Mon, 25 Nov 2024 16:45:58 +0000
Printing times and sales
View Count: 1080
[2014-02-22 03:24:25] |
TheCalmTrader - Posts: 32 |
Is there a way I can print time and sales? Also I dont think there is but is there a way to obtain option time and sales? |
[2014-02-24 18:43:09] |
Yes. This can be done by outputting 1 tick data to a spreadsheet and then from there you can Copy it or save it to a text file. You can then print it from a text editor. Refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails31.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
