Date/Time: Fri, 07 Feb 2025 14:57:34 +0000
how to define candlesticks not included in candle stick pattern finder?
View Count: 863
[2021-01-21 15:16:10] |
John - SC Support - Posts: 37808 |
We are not understanding your question. If you are asking if you can add additional patterns, then yes, the code for the Candlestick Pattern Finder is available in the file studies4.cpp in the ACS_Source directory under the main Sierra Chart folder. If it is something else, then let us know exactly what you are trying to accomplish. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-21 20:23:29] |
Adam Schwartz - Posts: 81 |
You can use the color bar based on alert condition and code this pretty easily in the alerts tab. As an example, for Close < Open, this would be ID0.SG4<ID0.SG1. You can also use color background based on alert condition which will make it more visible. Or you can use the spreadsheet system/alert study. Not sure if there is an easier way to do this.
[2021-01-22 21:32:49] |
As noted above, for simple items like what you want to highlight, the best/easiest way to do it is to use the Color Bar Based on Alert Condition. Refer to the information here: Color Bar Based on Alert Condition Also, refer to the information here for how to write alerts: Study/Chart Alerts And Scanning In particular, note the section on Referencing Data Other Than the Last Bar on the Alerts page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
