Date/Time: Fri, 21 Feb 2025 18:44:26 +0000
[Programming Help] - multiple entries ignored-trading system based on alert conditions
View Count: 533
[2021-01-21 02:53:08]
User907079 - Posts: 3
Hi, my 2nd buy entry signal is ignored because working orders exits. I referred to the BuyEntry knowledge doc and my setup do not meet any of the conditions that could result in multiple entries being ignored. I am using an OCO group per entry so after my 1st buyentry, there are only 2 working sell orders (OCO), in that case the 2nd by entry signal will not result in more than my max position limit of 2. I also allowed multiple entries but cannot set CancelAllWorkingOrdersOnExit to yes because that would also cancel my OCO orders from my 1st entry. What is causing this?
imagetrade service log.PNG / V - Attached On 2021-01-21 02:50:24 UTC - Size: 34.66 KB - 210 views
imagebuyentry setting.PNG / V - Attached On 2021-01-21 02:50:59 UTC - Size: 63.08 KB - 185 views
imagechart.PNG / V - Attached On 2021-01-21 02:51:05 UTC - Size: 3.77 KB - 189 views
[2021-01-22 14:58:40]
Sawtooth - Posts: 4174
Set "Allow Entry With Working Orders" to Yes.
