Date/Time: Fri, 21 Feb 2025 18:15:31 +0000
Possible to trade own live account / Topstep combine at the same time on one instance?
View Count: 794
[2021-01-21 02:02:40] |
SabikiSensei - Posts: 76 |
I currently have a funded account with Philip Capital and will soon be assigning it to the SC order routing service. I am currently working through TST's combine with the Rithmic bridge. I assume that I will be able to select my account connected with Philip Capital once it is assigned to the SC order routing service through Order Allocation to Trading Account?
Date Time Of Last Edit: 2021-01-21 03:35:59
[2021-01-21 03:31:29] |
Per the documentation on Order Allocation to Trade Accounts "The trade accounts to which the orders can be copied, will be those Trade Accounts that available on the username that is used to login to the Trading service. In the case of when using the Sierra Chart Order Routing Service, these trading accounts can be with the same clearing firm or different clearing firm, all on the same connection." I will have different clearing firms AND different connections.. Rithmic and Denali so I'm a bit confused here. Date Time Of Last Edit: 2021-01-21 03:35:18
[2021-01-21 15:10:49] |
John - SC Support - Posts: 38111 |
You cannot use the Order Allocation to Trade Accounts feature with the setup that you are stating. As you noted above, that feature only works if the accounts are available through the same login, typically this means through the same broker. You would need to have 2 different installations of Sierra Chart to really do what you are stating and manage each of them separately. Refer to the information here: Using Multiple Data and Trading Services at the Same Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
