Date/Time: Fri, 21 Feb 2025 18:27:22 +0000
TPO singles extension ALERT question
View Count: 688
[2021-01-21 01:38:51] |
User922418 - Posts: 13 |
Hi, How can I get an alert (either sound alert, or email alert) once a single's extension line has completed itself, say on a minute TPO chart, which I'm running, and the live price either trades above or below that line extension? Thanks and I look forward to your reply. |
[2021-01-23 11:49:21] |
There is not support for basing an alert on TPO chart single extensions.
