Date/Time: Fri, 21 Feb 2025 18:50:26 +0000
[Programming Help] - ø
View Count: 513
[2021-01-20 20:34:19]
sgne - Posts: 109
ø
Date Time Of Last Edit: 2024-12-05 04:10:34
[2021-01-22 17:34:27]
Sawtooth - Posts: 4174
If you are in a position, a reversal would require a Market exit with a new Limit placement.
Why sometimes you get the exit without a new Limit, I can't say.
[2021-01-22 20:03:48]
If you're in a position, how would only the placement of an opposing Limit order reverse your position?
Wouldn't you need to go flat first?
How would a Limit exit work in a reversal since generally price needs to trade thru a limit order?
The reversal would want to place an opposing Limit when you're still in a position, and if you didn't first exit and it filled, you'd just be flat.
Cells J71-J74 apply to cells J22-J25 respectively, which apply to columns K-N.
So if you have no formulas in L3/N3, J72/J74 and J23/J25 would have no affect because the trigger comes from columns L/N.
When using Reversals, L3/N3 formulas that match M3/K3 will likely cause issues.
