Date/Time: Thu, 06 Mar 2025 04:30:10 +0000
How to download data in a chartbook to a Excel spreadsheet?
View Count: 1260
[2021-01-20 16:42:12] |
User781913 - Posts: 12 |
How can I download the data in a chartbook including Rang per Bar (in ticks) and Number Bars Calculated Values to a Excel spreadsheet?
[2021-01-20 18:02:00] |
John - SC Support - Posts: 38425 |
In order to export the Bar Data and Study data use the Edit >> Export Bar and Study Data to Text File option. Refer to the information here: Edit Menu: Edit >> Export Bar and Study Data to Text File Just be aware that the Numbers Bars data is not available for export. In order to get the Numbers Bars data, you would have to create a program using ACSIL. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
