Date/Time: Fri, 21 Feb 2025 18:33:50 +0000
Possible to add unique text note to a trade in trade activity
View Count: 486
[2021-01-20 15:06:48] |
osaga - Posts: 53 |
Hello I know how to set the Notes Tag in the Trade Window 'SET' tab and how it works. What I want is to add a note to a trade in the Trade Activity Log after that trade has been closed. I want to easily mark my trades as a Pull Back, Fade, etc. It is not convenient or practical to have to change the trade configuration based on the trade I am about to take. Is it possible to mark trades after they are done? Regards, Oshine |
[2021-01-25 08:40:43] |
You are able to edit the Trade Activity data lines individually and then change the Note field. Refer to: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
